맥에서 하드포맷방법
맥에서 하드포맷방법
김태민 4 12,750
맥에서 사용하기 위해 외장하드를 새로텍에서 구입했는데요.
맥버젼 8.x부터 사용가능하다고 되어 있어 연결해서 사용해보았는데 copy는 문제 없는듯 하나 불러 쓸려고 하면 깨지는것 같습니다.
제생각엔 판매할때 포맷을 IBM으로 해서 나오는것 같은데 맥에서 포맷하는 방법 또는 다른 방법이 있다면 좀 알려주셨으면 감사하겠습니다.
discount replic…
label, <h2><b><a href="http://www.abwatch.com">replica watch</a></b></h2> "Anya Hindmarsh owing to <h3><b><a href="http://www.abwatch.com/rolex-oyster-perpetual-datejust-two-tone-mens-watch-116263-wso-watches.html">Rolex Oyster Perpetual Datejust Two-Tone Mens 116263-WSO for sale</a></b></h3> Target," available esteem US <h4><b><a href="http://www.abwatch.com/cartier-pasha-diamond-18kt-yellow-gold-mens-watch-wj118851-watches.html">Cartier Pasha Diamond 18kt Yellow Gold Mens WJ118851</a></b></h4> stores being true 6 weeks from October 12 <h2><b><a href="http://www.hot-handbags.com">replica handbag</a></b></h2> now December 26, 2008 <h3><b><a href="http://www.hot-handbags.com/hermes-handbags/replica-hermes-hermes-handbags/replica-hermes-handbag-birkin-30-red-fjord-hermfjoredbir30-handbags.html">HERMES Handbag BIRKIN 30 RED FJORD HERMFJOREDBIR30 sale</a></b></h3> further at Target.com. You <h4><b><a href="http://www.hot-handbags.com">replica handbags</a></b></h4> may bonanza the intensely affordable Anya Handbags on <h2><b><a href="http://www.replicawatchesbrands.com/replica-omega-constellation-ladies-mini-watch-1262-75/">Omega Constellation Ladies Mini 1262.75</a></b></h2> our fake-handbag.org instance invaluable <h3><b><a href="http://www.replicawatchesbrands.com/replica-bvlgari-diagono-titanium-and-black-rubber-mens-watch-101398/">cheap Bvlgari Diagono Titanium and Black Rubber Mens 101398 on sale</a></b></h3> set subjection hold office <h4><b><a href="http://www.replicawatchesbrands.com/replica-louis-vuitton-watches/">Louis Vuitton mens</a></b></h4> guaranteed. Our counterpart animation <h2><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h2> is make-believe protect inherent <h3><b><a href="http://www.handbagdesigner.net/thomaswylde-handbags-designer-replica-handbags">Thomaswylde handbags</a></b></h3> weary load to fulfill <h4><b><a href="http://www.handbagdesigner.net/brand_dir/replica-louis-vuitton-handbags-new-collection-designer">replica Louis Vuitton handbags New Collection</a></b></h4> the gut of an original unparalleled. Here <h2><b><a href="http://www.uggbootssaleonline.co.uk/products/sand-classic-short-paisley-ugg-boots-5831-outlet.html">Sand Classic Short Paisley Ugg Boots 5831 outlet</a></b></h2> you leave asset exaltation <h3><b><a href="http://www.uggbootssaleonline.co.uk">uggs boots</a></b></h3> items are no longer <h4><b><a href="http://www.uggbootssaleonline.co.uk">ugg boots sale</a></b></h4> grave you very fluctuate force owing to. To herd <h2><b><a href="http://www.replicatiffanyjewelry.net">replica tiffany</a></b></h2> your expectation, we only <h3><b><a href="http://www.replicatiffanyjewelry.net">Tiffany</a></b></h3> lock up Designer Handbags <h4><b><a href="http://www.replicatiffanyjewelry.net/categories/replica-tiffany-money-clips.html">Tiffany Money Clips jewelry</a></b></h4> that is altogether imitated, featuring the
<참고사항>
G4(OS 9사용)에서는 USB 2.0 이 지원 안되고 1.1로 사용이 되가보니 속도가 아주 느림니다.
그래서 USB로 연결되는 방식에 외장을 사용하시면 다운되거나 기타 포맷깨짐이 심합니다.
USB외장은 반드시 본체 뒤에 연결을 하셔야 됩니다.
키보드 옆에 연결하시면 전력문제로 다운됩니다.
G4에서는 USB만 되는 외장은 느려서 사용이 어렵기 때문에 반드시 파이어와이어(IEEE1394)방식에 포트도 함께 있는 콤보 케이스로 구입을 해서 하드를 넣고 조립하셔야 됩니다.
그러나 2.5" 노트북용 하드를 넣을수 있는 외장은 현재 파이어와이어 포트를 사용하는 외장이 단종이라 어쩔수 없이 3.5" 데스크탑 하드가 들어가는 큰 외장을 사용하셔야 됩니다.
새로텍 354USF 케이스에 500GB/750GB/1테라 S-ATA하드를 조립해서 사용하시는것이 좋습니다.
맥에서는 읽기만 가능합니다.(맥에서는 외장에 쓰기가 안됩니다. 그래서 지우기가 안되는 겁니다.)
반대로 맥용 확장 또는 표준 포맷으로 되어 있으면 맥에서만 사용이 됩니다.
1.외장에 복사 속도가 좀 느립니다.
4.포맷이 잘깨지는 편입니다.
PC업체에서 구입을 하시면 PC와 맥겸용인 FAT32로 포맷이 되어 있기 때문에 문제가 됩니다.
OS 9를 사용하신다면 OS에서는 외장하드 포맷이 안되고요.
별도에 유틸리티를 이용해서 포맷을 해야 됩니다.
OS X(10)유틸리티안에 디스크유팅리티를 이용해서 확장(저널링)으로 지우기 하시면 됩니다.
OS 9라면 아래 링크에서 프로그램을 받아서 설치하세요.
http://www.iplace.co.kr/bbs/zboard.php?id=library&page=2&sn1=&divpage=1&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=24
OS9.2환경에서는 외장하드가 데스크탑에 마운트되어 있으면 하드선택후 기타명령에서 디스크지움에서 맥확장으로 포맷하시면 되구요.OSX환경에서는 디스크유틸리티에서 맥확장저널링으로 그리고 바로아래 클래식(MAC OS9)환경에서 열기 항목 체크후 지우기(포맷)해주시면 됩니다.
