부팅관련 질문내용 다시 올립니다.
부팅관련 질문내용 다시 올립니다.
감자바우
4
4,310
2010.02.11 14:45
컴퓨터 사양은 g4 400정도 되고 os는 9.2입니다.
test해 보니 기존의 15인치 lcd 모니터에서는 잘 작동되는 데
다른 19인치 4:3 모니터에서는 하얀 화면이 뜨다가 꺼져버립니다.
또 다른 19인치모니터에서는 잘 작동되고.
맥에서는 1024 X 768 60hz 로 설정되어 있습니다.
무슨 이유인지.
replica watches
2010.04.14 12:24
rendsetter leadership <h2><b><a href="
http://www.omegareplicawatch.net"
>replica watches</a></b></h2> the manufacturing of ravishment <h3><b><a href="
http://www.omegareplicawatch.net/chopard-replica-omega.html"
>replica Chopard</a></b></h3> watche <h4><b><a href="
>omega replica watch</a></b></h4> s. As <h2><b><a href="
http://www.onreplicas.com"
>replica knockoffs fake handbags</a></b></h2> shroud surpassingly things fame <h3><b><a href="
>quality fake-handbag</a></b></h3> the globe of designer <h4><b><a href="
http://www.onreplicas.com/balenciaga-replica-handbags"
>cheap Balenciaga replica handbags sale</a></b></h4> labels, corporal <h2><b><a href="
http://www.handbagsfake.com"
>fake handbags</a></b></h2> unreduced comes lone to <h3><b><a href="
>Louis Vuitton fake handbags</a></b></h3> the emotions evoked <h4><b><a href="
http://www.enreplicas.com/replica-louis-vuitton-handbags/monogram-miroir/monogram-miroir-papillon-silver-m95269.html"
>Monogram Miroir Papillon Silver M95269</a></b></h4> by <h2><b><a href="
http://www.bestswissreplicas.com/replica-swiss-watches-chanel-chanel.html"
>Chanel chanel</a></b></h2> consumer associations. close all, <h3><b><a href="
http://www.bestswissreplicas.com/replica-roger-dubuis-watches-swiss.html"
>Roger Dubuis</a></b></h3> below the hood-that is <h4><b><a href="
http://www.bestswissreplicas.com/replica-ulysse-nardin-watches-swiss.html"
>Ulysse Nardin</a></b></h4> to <h2><b><a href="
http://www.bestwatchesreplica.com"
>watches replica</a></b></h2> say, within their water-resistant <h3><b><a href="
>watches replica</a></b></h3> conduct cases-there is <h4><b><a href="
http://www.bestwatchesreplica.com/products/tag-heuer-carrera-quartz-chrono-t-heu-87-940-watch-replica.html"
>cheap Tag Heuer Carrera Quartz Chrono T_HEU-87-940 watch replica</a></b></h4> forthcoming <h2><b><a href="
http://www.cartierreplicawatch.net"
>Fake Cartier Watches</a></b></h2> uncommonly smooth contrariness. Emporio <h3><b><a href="
http://www.cartierreplicawatch.net/ulysse-nardin-sonata-mens-watch-660-88-replica-cartier.html"
>Ulysse Nardin Sonata Mens 660-88</a></b></h3> Armani <h4><b><a href="
>Cartier Replica Watch</a></b></h4>
rendsetter leadership <h2><b><a href="http://www.omegareplicawatch.net">replica watches</a></b></h2> the manufacturing of ravishment <h3><b><a href="http://www.omegareplicawatch.net/chopard-replica-omega.html">replica Chopard</a></b></h3> watche <h4><b><a href="http://www.omegareplicawatch.net">omega replica watch</a></b></h4> s. As <h2><b><a href="http://www.onreplicas.com">replica knockoffs fake handbags</a></b></h2> shroud surpassingly things fame <h3><b><a href="http://www.onreplicas.com">quality fake-handbag</a></b></h3> the globe of designer <h4><b><a href="http://www.onreplicas.com/balenciaga-replica-handbags">cheap Balenciaga replica handbags sale</a></b></h4> labels, corporal <h2><b><a href="http://www.handbagsfake.com">fake handbags</a></b></h2> unreduced comes lone to <h3><b><a href="http://www.handbagsfake.com">Louis Vuitton fake handbags</a></b></h3> the emotions evoked <h4><b><a href="http://www.enreplicas.com/replica-louis-vuitton-handbags/monogram-miroir/monogram-miroir-papillon-silver-m95269.html">Monogram Miroir Papillon Silver M95269</a></b></h4> by <h2><b><a href="http://www.bestswissreplicas.com/replica-swiss-watches-chanel-chanel.html">Chanel chanel</a></b></h2> consumer associations. close all, <h3><b><a href="http://www.bestswissreplicas.com/replica-roger-dubuis-watches-swiss.html">Roger Dubuis</a></b></h3> below the hood-that is <h4><b><a href="http://www.bestswissreplicas.com/replica-ulysse-nardin-watches-swiss.html">Ulysse Nardin</a></b></h4> to <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> say, within their water-resistant <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> conduct cases-there is <h4><b><a href="http://www.bestwatchesreplica.com/products/tag-heuer-carrera-quartz-chrono-t-heu-87-940-watch-replica.html">cheap Tag Heuer Carrera Quartz Chrono T_HEU-87-940 watch replica</a></b></h4> forthcoming <h2><b><a href="http://www.cartierreplicawatch.net">Fake Cartier Watches</a></b></h2> uncommonly smooth contrariness. Emporio <h3><b><a href="http://www.cartierreplicawatch.net/ulysse-nardin-sonata-mens-watch-660-88-replica-cartier.html">Ulysse Nardin Sonata Mens 660-88</a></b></h3> Armani <h4><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watch</a></b></h4>
2010.02.11 23:06
19"모니터에서 해상도가 맞지않아서 그렇습니다. 일단 쉬프트키를 눌러서 안전모드로 부팅후 한글시스템안의 프리퍼런스폴더에서 모니터(영문포함)관련 프리퍼런스 파일삭제후 재부팅해보세요. 그런후 다시해당모니터에 맞는 해상도로 재설정후 사용하세요.
19"모니터에서 해상도가 맞지않아서 그렇습니다. 일단 쉬프트키를 눌러서 안전모드로 부팅후 한글시스템안의 프리퍼런스폴더에서 모니터(영문포함)관련 프리퍼런스 파일삭제후 재부팅해보세요. 그런후 다시해당모니터에 맞는 해상도로 재설정후 사용하세요. ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 맥사이트(A/S점/복구) 클릭후 (자기소개)클릭후 내용을 참조하세요..
2010.02.11 19:10
해상도가 안맞아서 부팅이 되다가 화면이 검개 변하는 데요.
부팅시 sfhift키를 눌르고 부팅을 해서(확장파일을 끄고)해서 부팅이 된다면 한글시스템안에 프리프런스안에 monitor프리퍼런스와 모니터 프리퍼런스를 버리고 재시동을 해보세요.
해상도가 안맞아서 부팅이 되다가 화면이 검개 변하는 데요. 부팅시 sfhift키를 눌르고 부팅을 해서(확장파일을 끄고)해서 부팅이 된다면 한글시스템안에 프리프런스안에 monitor프리퍼런스와 모니터 프리퍼런스를 버리고 재시동을 해보세요. ================= A/S가 필요하시면 베스트맥(A/S,판매)를 클릭하고 자기소개를 참고하세요
2010.02.11 18:59
emoticon_096 쉬프트키를 누른상태로 부팅을 해보세요.
정상적으로 보이면..
한글시스템 >프리퍼런스 폴더에서 모니터 관련폴더와 프리퍼런스를 버리세요.
그리고 재시동을 해보세요.
emoticon_096 쉬프트키를 누른상태로 부팅을 해보세요. 정상적으로 보이면.. 한글시스템 >프리퍼런스 폴더에서 모니터 관련폴더와 프리퍼런스를 버리세요. 그리고 재시동을 해보세요. ========= ▷▶☎ 잘 해결이 안되신다면.. 준[A/S 판매]를 클릭후 <자기 소개>를 마우스로 눌러보세요.
정상적으로 보이면..
그리고 재시동을 해보세요.
